geoffleach
Jun 20, 2018Aspirant
R7000 Nighthawk
Laptop looses 1/3 of wifi signal strength when the laptop moves through a door. Distance to router at that point is 10 feet. Wall is conventional wood-framed. On both sides of the wal there are fully...
- Jun 20, 2018
Sounds about right to me. From what you describe the wifi is going through a wall plus two layers of books plus steel shelving. Remember wifi does not go around corners.
myersw
Jun 20, 2018Master
- geoffleachJun 20, 2018Aspirant
Hmmmm ... interesting. Other than moving the router, is there a solution?
- antinodeJun 20, 2018Guru
> [...] Remember wifi does not go around corners.
This would make them the first EM waves ever not to experience
diffraction.- myerswJun 21, 2018Master
diffraction.True, but remember that signals that spread or bounce are not going to provide as good of a signal as nothing inbetween.
- michaelkenwardJun 21, 2018Guru - Experienced User
And diffraction is not "going round corners" as most people understand it, just a red herring from someone who would rather throw in a cheap jibe than follow the issue.
Back to the point, following your earlier response, we don't know which wifi band the user has on the laptop. If they are on 5 GHz, 2.4 GHz might give better range.
Nor do we know if this signal loss affects their experience. Maybe they have just found a signal meter and want to play with numbers.
