geoffleach's avatar
geoffleach
R7000 Nighthawk
Laptop looses 1/3 of wifi signal strength when the laptop moves through a door. Distance to router at that point is 10 feet. Wall is conventional wood-framed. On both sides of the wal there are fully...
  • myersw's avatar
    Jun 20, 2018
    Sounds about right to me. From what you describe the wifi is going through a wall plus two layers of books plus steel shelving.  Remember wifi does not go around corners.
