Demicos
Feb 21, 2022Tutor
R7000 Nightnawk | Getting half of my Spectrum subscribed speed when hardwired through router
Hello everyone, I have an R7000 Nighthawk. I have the 400Mbps package from Spectrum, and when my desktop computer is hardwired into their Modem (EN2251) I am receiving 450Mbps or higher. The issu...
- Feb 22, 2022
did you ever factory reset and test if from the defaults?
problem with having qos/access control/traffic monitoring/parental controls enabled is that they disable cut through forwarding. Its the service needed to hit gigabit speeds. And I've seen it get disabled because those services were on but not get re-enabled when the services were disabled. So try a factory reset. Test it from its default speeds.
Feb 22, 2022Guru - Experienced User
Demicos
Feb 22, 2022Tutor
plemans First off - I want to say thank you, as I have seen many of your other posts on other threads with similar issues. I have yet to Factory Reset the device. Would you suggest going back to original / changing firmware prior to Factory Resetting? Please note that I am on the latest Firmware.
- plemansFeb 22, 2022Guru - Experienced User
I would try it on the version you're on first. there's been a lot of firmware updates since the version that we (on here) consider the most stable. And for most people, it works fine.
What actual version number are you on?
