Demicos
Feb 21, 2022Tutor
R7000 Nightnawk | Getting half of my Spectrum subscribed speed when hardwired through router
Hello everyone, I have an R7000 Nighthawk. I have the 400Mbps package from Spectrum, and when my desktop computer is hardwired into their Modem (EN2251) I am receiving 450Mbps or higher. The issu...
- Feb 22, 2022
did you ever factory reset and test if from the defaults?
problem with having qos/access control/traffic monitoring/parental controls enabled is that they disable cut through forwarding. Its the service needed to hit gigabit speeds. And I've seen it get disabled because those services were on but not get re-enabled when the services were disabled. So try a factory reset. Test it from its default speeds.
Demicos
Feb 22, 2022Tutor
Factory reset did it. Pretty dumb that Qos & Traffic Meter continue to kneecap your speeds even if they are disabled.
Appreciate your help plemans
Feb 22, 2022Guru - Experienced User
Glad it worked!
A backup is always a good thing to have for next time :)
- KitsapFeb 22, 2022Master
When you save a configuragion backup, it is also a good idea to annotate in the file name the firmware version installed when the backup was made. In general it is not good/succesful practice to restore a backup to a different firmware version than was installed when it was saved.
