algje
Nov 02, 2016Aspirant
r7000 no usb 3.0 with latest firmware
I know this has been much discussed, but I couldn't find the solution in any of the topics after searching for days. Has there been a solution to the usb 3.0 port not working, whereas the usb 2.0 is ...
- Dec 18, 2016
Hi nexusone,
Please check the KB article for the external drives that works with the router.
http://kb.netgear.com/18985/ReadySHARE-USB-Drives-Compatibility-List?cid=wmt_netgear_organic
JamesGL
Nov 03, 2016NETGEAR Employee Retired
Hi algje,
1. Did the issue happen before updating the firmware?
2. What is the model number of the drive?
3. Do you have other 3.0 drive to check the USB 3.0 port of the router?
JamesGL
Community Team
- algjeNov 07, 2016Aspirant
Hi James,
Thanks for replying. The answer to question 1 I don't know, since teh firmware was upgraded before I did anything, so I've only had this version. The drive is a seagate srd00f2. It worked fine until I unplugged the router. After that I've tried resetting the router (as per your advice in another topic) and that seemed to work until the router was unplugged again. I've just tried resetting the router again, but this time it doesn't seem to have helped. I think there was some language update somewhere in between that.
I haven't checked another drive, as this drive was recognized before, so the drive itself seems fine.
Thanks.
- JamesGLNov 08, 2016NETGEAR Employee Retired
Hi algje,
1. If you connect the drive in USB 2.0, will it work?
2. If not, will your computer detects the drive if you connect it directly?
3. Please try using a different drive just to isolate.
JamesGL
Community Team- algjeNov 10, 2016Aspirant
Hi James,
I've tried a Western Digital Elements 1TB drive, exactly the same problem; Works fine on the router's usb 2.0 port and my laptop (also usb 3), but not in the usb 3.0 port on the router...
Thanks
