algje
Nov 02, 2016Aspirant
r7000 no usb 3.0 with latest firmware
I know this has been much discussed, but I couldn't find the solution in any of the topics after searching for days. Has there been a solution to the usb 3.0 port not working, whereas the usb 2.0 is ...
- Dec 18, 2016
Hi nexusone,
Please check the KB article for the external drives that works with the router.
http://kb.netgear.com/18985/ReadySHARE-USB-Drives-Compatibility-List?cid=wmt_netgear_organic
nexusone
Dec 15, 2016Tutor
Seens like this has been a topic of discussion for like a year now so i tend to think the "firmware" issue is a cover up for a disfunctional 3.0 port.
Can the admins confirm that external 3.0 hard drives actually work when plugged into the USB 3.0 port in the front of the router or is the only option the 2.0 port?
This is misleading because the router advertises the ability to connect a drive at 3.0 speeds.
Are there any known limitiations? Has anyone ever been able to recognize a drive in the 3.0 port?
Thanks
- JamesGLDec 18, 2016NETGEAR Employee Retired
Hi nexusone,
- JamesGLDec 22, 2016NETGEAR Employee Retired
Hi nexusone,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
