errolnorm
Apr 17, 2021Aspirant
R7000 not connecting to Xbox one
After resetting my router password, I am no longer able to login to my Xbox one
michaelkenward
Apr 18, 2021Guru - Experienced User
Your subject says "R7000 not connecting to Xbox one". You might do better to think of it the other way round "Xbox one not connecting to R7000".
Is this a wired connection? Wifi?
Which password is that? What happens when you try?
