NgUser57
May 30, 2021Follower
R7000 not finding newest firmware update
Logged in to router and under administration router update have checked for new version and get the reply that it has the current version. However the current version is V1.0.9.88_10.2.88. On the sup...
- May 30, 2021
Its failry common with that router.
You can manuall update.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
I'd recommend doing it over a hardwired connection. If you do have issues, try a factory reset and new install process (not using a backup)
May 30, 2021Guru - Experienced User
