mordecai131
Nov 05, 2020Tutor
R7000 Not Getting Gigabit Speed Paired with 716GE ONT
Hello All, So I've had this R7000 for a while and have used it with all my networks up until now. Recently I moved and signed up for CenturyLink fiber and they said I had to use their equipment. Aft...
Nov 05, 2020Guru - Experienced User
what firmware are you on?
I'd also make sure access control and parental controls is disabled.
If you've had those enabled, I'd factory reset the router and do a clean install on it. Make sure not to restore from a backup.
mordecai131
Nov 05, 2020Tutor
It's on firmware V1.0.11.110_10.2.100 and from the looks of it both Access Control and Parental controls are disabled. Just before I set up my router I did do a factory reset and used all the default settings except for those that were needed like PPPoE and VLAN tagging to connect to the CenturyLink network.
- plemansNov 05, 2020Guru - Experienced User
I'd try the 1.0.9.42 firmware for the R7000.
install that over a hardwired connection, factory reset and do a clean install again.
- mordecai131Nov 05, 2020Tutor
I'll give it a shot, probably wont be able to update till tomorrow morning now that the family is up and using the internet.
- mordecai131Nov 10, 2020Tutor
Sorry for the delayed response to the topic. So after flashing to the older firmware and factory resetting I was able to get up to 400mb/s. That same day though my wife had me switch back to the ISP provided router. After switching back everything was running extremly slow and when contacting my ISP I was told I was getting BIP8 errors. After power cycling the ONT everything seems to be fine but I didn't want to risk causing more issues so I boxed up the R7000 and haven't touched it since. If I had a way to guarantee gigabit from the R7000 without causing more possible issues with my ISP I would persue the switch further but I'm not sure how I can do that.
