Isaac2156
Aug 17, 2019Aspirant
R7000 not getting iPv6 on my xbox & Packet Loss
Hey, I've been having problems recently with my R7000, I love to game on my xbox but these past few days are not letting me play, first, I'm not getting iPv6 on my xbox, it just says I'm connected to...
- Aug 18, 2019
This firmware version has a lot of issues, as do the past few releases. For the R7000, it is recommended to run the .42 firmware, which is the last known "working" one.
Go to https://www.netgear.com/support/product/r7000.aspx#download
and click on the "View Previous Versions" plus sign on the lower left, Get the .42 version, flash it and do a factory reset then reconfigure from scratch
Isaac2156
Aug 18, 2019Aspirant
The newest one that came out I believe, I checked on the website and it says," Firmware version V1.0.9.88_10.2.88"
microchip8
Aug 18, 2019Master
- Isaac2156Aug 18, 2019AspirantIt worked! Thank you for helping me.
- FirmwarefailureAug 31, 2019Tutor
What do you mean by Flash it? I updated my R7000 and the thing quit working. NOTHING. Called Netgear support and they were terrible. Wouldn't help me at all. They wanted me to pay $140 USD for something that their update caused. It was working perfectly until the update.
- antinodeAug 31, 2019Guru
> What do you mean by Flash it? [...]
A poorly chosen term, probably meaning "load the firmware".
> [...] I updated my R7000 [...]
How, exactly?
> [...] and the thing quit working. NOTHING. [...]
What, exactly, does "NOTHING" mean to you? LED indicators all dark?
"NOTHING" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
If there was a failure when you updated the firmware, then you may
see a flashing Power indicator. In such a case, all router functions
may fail, and you might be a candidate for the TFTP recovery scheme.
See, for example:- FirmwarefailureAug 31, 2019Tutor
My bad wording:) I updated on my cell phone. The Nighthawk app I have on my IPhone said I had an update available. I updated, which went well. Then it said connect your device ( cell ) to network - press continue. I did. That's when I lost all internet connectivity. The only light that comes on now is the orange power light. I can't get the router to start "routing" signal.
