Rvreeswijk
Apr 04, 2020Aspirant
R7000 not portforwarding
Dear, I want to host my own minecraft server just for my friends, i am new in the portforwarding scene and do not know much about this. So i followed a youtube tutorial of how to portforward for n...
- Apr 05, 2020
> [...] But if i want to set the modem to bridge mode, my netgear router
> is not working. [...]There are many kinds of "not working". "not working" is not a useful
problem description. It does not say what you did. It does not say
what happened when you did it. As usual, showing actual actions
(commands) with their actual results (error messages, LED indicators,
...) can be more helpful than vague descriptions or interpretations.I know nothing about how your EPC3940L was configured when it was a
modem+router. You might need to do things to the R7000 to make it work
with your ISP when it's your main/only router.Did you try a settings reset on the R7000 after you changed the
EPC3940L to modem-only mode?> [...] See picture 2. (Router IP:192.168.1.1) because the C (In
> A.B.C.D) is a 1, i cannot reserve a adress for my port. [...]
Regarding "cannot", see "not a useful problem description [...]",
above.LAN addresses like "192.168.1.1" (for the R7000) and "192.168.1.2"
(for your computer) seem normal to me. You should still have a reserved
address for your server system.> [...] Also with that C in my ipv4 adress i cannot port forward via my
> modem because its a closed IPv4?Why not? Regarding "cannot", again, see "not a useful problem
description [...]", above.> [...] call my ISP tomorrow [...]
They may be able to tell you if you need to specify any special
settings on your (R7000) router when you're not using the router in the
EPC3940L.
Rvreeswijk
Apr 05, 2020Aspirant
I think i have found the solution. My modum is in router modes aswell, so in my netwerk i have 2 routers. See picture 1. But if i want to set the modem to bridge mode, my netgear router is not working. Or even worse, if i do something in my modem (that i got from the ISP) and save it, the modem will crash in my opinion. It happend this evening twice. After reinstalling my modem and netgear router i had finally my internet back. After the hole re-install progress my PC generated a new Ip adres for my netgear router. See picture 2. (Router IP:192.168.1.1) because the C (In A.B.C.D) is a 1, i cannot reserve a adress for my port. Also with that C in my ipv4 adress i cannot port forward via my modem because its a closed IPv4?
My PC has the IPv4: 192.168.1.2 (picture 3)
My modem is 15 years old. I dont know if that is long for a modem? But im gonna call my ISP tomorrow to ask if they can help me out.
I will keep you up to date with the status.
Thx!
antinode
Apr 05, 2020Guru
above.
EPC3940L.
