ericdmurphy
Mar 09, 2021Aspirant
R7000 Not reading external hard drive full space.
I have an external hard drive that is a 2T. It is installed into a box that has external power and a usb cable. When you plug the usb cable into any computer, it reads that there is space of 1.8 T....
michaelkenward
Mar 10, 2021Guru - Experienced User
ericdmurphy wrote:
WHen I plug it into the router it only shows that it is 922GB.
The usual cause of that is drive with separate partitions. ReadySHARE can handle just the one partition.
- ericdmurphyMar 10, 2021Aspirant
So I thought about that, but I plugged this hard into the computer, and it reads only the one partition, and it reads that there is 1.8T total. When plugbed back directly into the router, it reads 922G again.
- michaelkenwardMar 10, 2021Guru - Experienced User
That doesn't tell you about the partitioning. You need to check that in something like Windows disk manager.
- ericdmurphyMar 10, 2021AspirantThis is plugged into the computer, reads fine.
