Dish
Jun 25, 2016Aspirant
R7000 not restarting after hitting Wifi & WPS buttons
Looking for help with my r7000. It was installed and working fine for months but my son hit the Wifi WPS buttons and now it won't restart. I just have the power & internet lights on I should say I'...
- Jun 26, 2016I had to do a hard reset but it worked. Thank you for your advice
Problem resolvedđ
sktn77a
Jun 25, 2016Virtuoso
Did you remove power and reboot the router and still have the same problem? If so, then yes, do a hard reset. Wifi security password should be reset to default (which is printed on the router).
