song_jemica
Oct 17, 2021Aspirant
R7000 not showing connected devices
Last week I updated my Nighthawk R7000 firmware to V1.0.11.128_10.2.112. Now it only shows 7 of the 22 devices on my network under “Device Manager” in the app and “Attached Devices” in the web admin...
- Nov 02, 2021
Thanks, I did a factory reset and reloaded the firmware. Then manual setup everything. Seems to have solved the issue. Thank you!
garylwe
Oct 18, 2021Initiate
After the firmware update to V1.0.11.128_10.2.112 only 3 devices showed up in the nighthawk app. I logged into the router and under Basic tab clicked Attached Devices and the same 3 devices showed. I went to the Advanced tab, clicked Administration,
Attached Devices and all the 16 devices showed up. I then clicked Security, Access Control and I put a check next to Turn on Access Control and Apply and then all the devices appeared both on the nighthawk app and the basic tab, attached devices. Hope this helps someone....
