song_jemica
Oct 17, 2021Aspirant
R7000 not showing connected devices
Last week I updated my Nighthawk R7000 firmware to V1.0.11.128_10.2.112. Now it only shows 7 of the 22 devices on my network under “Device Manager” in the app and “Attached Devices” in the web admin...
- Nov 02, 2021
Thanks, I did a factory reset and reloaded the firmware. Then manual setup everything. Seems to have solved the issue. Thank you!
garylwe
Oct 18, 2021Initiate
After the firmware update to V1.0.11.128_10.2.112 only 3 devices showed up in the nighthawk app. I logged into the router and under Basic tab clicked Attached Devices and the same 3 devices showed. I went to the Advanced tab, clicked Administration,
Attached Devices and all the 16 devices showed up. I then clicked Security, Access Control and I put a check next to Turn on Access Control and Apply and then all the devices appeared both on the nighthawk app and the basic tab, attached devices. Hope this helps someone....
Bill-D
Oct 19, 2021Apprentice
As a work-around with v128, I simply ignore the “Attached Devices” list because it's unreliable and I only use the “Access Control” list to see which devices are currently connected and currently not connected. The device names in the "Access Control" list also accurately match the names that I assigned to the devices in the "Address Reservation" list.
