song_jemica
Oct 17, 2021Aspirant
R7000 not showing connected devices
Last week I updated my Nighthawk R7000 firmware to V1.0.11.128_10.2.112. Now it only shows 7 of the 22 devices on my network under “Device Manager” in the app and “Attached Devices” in the web admin...
- Nov 02, 2021
Thanks, I did a factory reset and reloaded the firmware. Then manual setup everything. Seems to have solved the issue. Thank you!
song_jemica
Oct 20, 2021Aspirant
It only shows 7 of the 22 devices on my network under “Device Manager” in the app and “Attached Devices” in the web admin interface.
Only a small subset of my 2.4 GHz and hard-wired devices are visible. Many of the 2.4 GHz and none of the 5 GHz devices aren’t there. Both networks are active and Smart Connect is enabled shaglechatspin.
However, under “Access Control” in the admin interface, I can see everything, just not the band they’re connected to.
Yeah, my old setting is creating a problem for me. Btw thanks for the new set up. Its working fine now.
- BlackholexploreNov 02, 2021Aspirant
Same thing is happening to me. In addition, I lost the radios - nothing could connect and rebooting didn't help. I did a factory reset and reloaded the old configuration. Same issue - very few devices show in the lists, although the radios are now accepting connections.
Do you know which setting was causing the issue?
- FURRYe38Nov 02, 2021Guru - Experienced User
Try a factory reset and this time, don't load the backup configuration from file and see if problem still continues.
