JamieLyons's avatar
JamieLyons
Follower
Dec 29, 2019
R7000 Not showing internet
I just received the R7000 to replace an older Nighthawk that no longer works properly. (have to reset each day) I have a mobile Verizon M1000-39A4 that works fine and am able to connect all wifi cap...
  • plemans's avatar
    Dec 30, 2019
    The verizon M1000 has its own router built into it. If you're running the R7000 in router mode, you're in a double nat. You can try switching the R7000 over to AP mode so you only have 1 router on the network. Otherwise you'd need to place the M1000 in passthrough mode if you want to retain the routing features of the R7000. You'd need to contact verizon on how to do that.
    https://kb.netgear.com/30186/What-is-Double-NAT
