Jaragon
Jan 01, 2022Star
R7000 not showing or allowing control of all connected devices
Router will show under access control all devices but on app or login not showing all or allowing control.
Jan 02, 2022Guru - Experienced User
try installing the latest .128 firmware
Jaragon
Jan 02, 2022Star
It tells me no new firmware update
- plemansJan 02, 2022Guru - Experienced User
so download the firmware and manually update it.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- JaragonJan 02, 2022Star
I did the update but it is the same version as I am already running. There are other users having same issues. It seems as though after last update they are also having trouble.
so you said you're on the .126 firmware and the latest is .128.
Not the same version.
did you try a factory reset?
