pstenbo's avatar
pstenbo
R7000 not showing or connecting to Brother Printer
Brother 2270DW is not showing or connecting. Running Window 7 and Windows 10 on various PC's. Replaced older Netgear router where everything functioned and now does not show on R7000. Reset network s...
  • FURRYe38's avatar
    Try setting security to WPA and TPIK and test on the router with the printer for a wireless connection. You'll have to re-connect the printer wirelessly to the router again. Then try WPA2 and TPIK or AES and test.
    Might set the router to UP to 300Mb on 2.4Ghz and test as well.
