pstenbo
Apr 26, 2017Aspirant
R7000 not showing or connecting to Brother Printer
Brother 2270DW is not showing or connecting. Running Window 7 and Windows 10 on various PC's. Replaced older Netgear router where everything functioned and now does not show on R7000. Reset network s...
- Apr 28, 2017
Try setting security to WPA and TPIK and test on the router with the printer for a wireless connection. You'll have to re-connect the printer wirelessly to the router again. Then try WPA2 and TPIK or AES and test.
Might set the router to UP to 300Mb on 2.4Ghz and test as well.
pstenbo
Apr 28, 2017Aspirant
1. I tried wireless. Out of frustration I did connect it (wired) to the router and it works fine.
2. I cannot be viewed on a wireless network.
3. See question 1, works when it's wired.
4. Checked the attached deviers on the router UI and visible when wired, not visible when wireless.
Apr 28, 2017Guru - Experienced User
- JamesGLMay 03, 2017NETGEAR Employee Retired
Hi pstenbo,
We’d greatly appreciate hearing your feedback letting us know if you have tried the suggestion of FURRYNUTZ.
