ghost_hand
Oct 08, 2021Aspirant
R7000 not starting
One day I wanted to set my R7000 as acess point, so I reset the R7000. But I accidentally pressed the reset button while the router started just one second. Now the R7000 won't boot and everytime whe...
Oct 09, 2021Guru - Experienced User
Lots of things can go wrong with tftp. its sensitive to timings. As well as how you're using it.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
another thing to check is the power supply. If you have an older device or different device with the same exact voltage and polarity (you can have more amps but not less), try that one.
ghost_hand
Oct 18, 2021Aspirant
Thanks for your suggestions. However, I think that my R7000 is bricked and I have tried all the methods even with the nmrpflash and the tftp, it still doesn't unbrick.
