ghost_hand
Oct 08, 2021Aspirant
R7000 not starting
One day I wanted to set my R7000 as acess point, so I reset the R7000. But I accidentally pressed the reset button while the router started just one second. Now the R7000 won't boot and everytime whe...
michaelkenward
Oct 19, 2021Guru - Experienced User
ghost_hand wrote:
Now the R7000 won't boot and everytime when I started the router, it stays at the status which the power led, the internet led, port 1 led are in dim orange light, ports 2, 3, 4 leds are in light orange led.
The power LED is not white?
ghost_hand
Nov 02, 2021Aspirant
Yes, everytime when I power on the R7000, the power led is dim orange.
- FURRYe38Nov 02, 2021Guru - Experienced User
Try a different power supply with same voltage and amps.
- ghost_handNov 02, 2021Aspirant
Okay, I'll try it. Current power supply I am using for my R7000 is original since I bought R7000.
đ
- ghost_handNov 08, 2021AspirantI have tried another power supply and could supply
12V 4.5A
15V 4.5A
16V 4.5A
18V 4.5A
19V 4.5A
20V 4A
24V 4A
So I set all Volts except 12V, but it still remains at the status which I have described above.- michaelkenwardNov 08, 2021Guru - Experienced User
ghost_hand wrote:
So I set all Volts except 12V, but it still remains at the status which I have described above.I don't know what that means, but what you need is 12V and at least 3.5A.
15V might not cause damage, but 24V is way over the top.
