gaziou
Nov 09, 2016Aspirant
R7000 openVPN error
Hi All,
Please bear with me and my limited technical knowledge/skills....
I am trying to use openVPN with my R7000. I set up the VPN and download the setting files for mac os. And using Tunnelblick 3.6.8 (build 4625) to connect the my network. However it keeps waiting for server response.
The logs:
*Tunnelblick: OS X 10.12.1; Tunnelblick 3.6.8 (build 4625)
2016-11-09 09:33:28 *Tunnelblick: Attempting connection with r7000 using shadow copy; Set nameserver = 769; monitoring connection
2016-11-09 09:33:28 *Tunnelblick: openvpnstart start r7000.tblk 1337 769 0 1 0 1065330 -ptADGNWradsgnw 2.3.12
2016-11-09 09:33:28 *Tunnelblick: openvpnstart starting OpenVPN
2016-11-09 09:33:29 OpenVPN 2.3.12 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH] [IPv6] built on Oct 9 2016
2016-11-09 09:33:29 library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09
2016-11-09 09:33:29 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337
2016-11-09 09:33:29 Need hold release from management interface, waiting...
2016-11-09 09:33:30 *Tunnelblick: openvpnstart log:
Loading tap-signed.kext
OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
/Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3.12/openvpn
--daemon
--log
/Library/Application Support/Tunnelblick/Logs/-SUsers-Souj-SLibrary-SApplication Support-STunnelblick-SConfigurations-Sr7000.tblk-SContents-SResources-Sconfig.ovpn.769_0_1_0_1065330.1337.openvpn.log
--cd
/Library/Application Support/Tunnelblick/Users/ouj/r7000.tblk/Contents/Resources
--verb
3
--config
/Library/Application Support/Tunnelblick/Users/ouj/r7000.tblk/Contents/Resources/config.ovpn
--verb
3
--cd
--management
127.0.0.1
1337
--management-query-passwords
--management-hold
--script-security
2
--up
/Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -9 -a -d -f -m -w -ptADGNWradsgnw
--down
/Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -9 -a -d -f -m -w -ptADGNWradsgnw
--route-pre-down
/Applications/Tunnelblick.app/Contents/Resources/client.route-pre-down.tunnelblick.sh -9 -a -d -f -m -w -ptADGNWradsgnw
2016-11-09 09:33:30 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337
2016-11-09 09:33:30 MANAGEMENT: CMD 'pid'
2016-11-09 09:33:30 MANAGEMENT: CMD 'state on'
2016-11-09 09:33:30 MANAGEMENT: CMD 'state'
2016-11-09 09:33:30 MANAGEMENT: CMD 'bytecount 1'
2016-11-09 09:33:30 MANAGEMENT: CMD 'hold release'
2016-11-09 09:33:30 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2016-11-09 09:33:30 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2016-11-09 09:33:30 Socket Buffers: R=[196724->196724] S=[9216->9216]
2016-11-09 09:33:30 MANAGEMENT: >STATE:1478702010,RESOLVE,,,
2016-11-09 09:33:30 *Tunnelblick: Established communication with OpenVPN
2016-11-09 09:33:30 UDPv4 link local: [undef]
2016-11-09 09:33:30 UDPv4 link remote: [AF_INET]216.49.158.240:12974
2016-11-09 09:33:30 MANAGEMENT: >STATE:1478702010,WAIT,,,
2016-11-09 09:34:30 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2016-11-09 09:34:30 TLS Error: TLS handshake failed
2016-11-09 09:34:30 SIGUSR1[soft,tls-error] received, process restarting
Could anybody help me? Thank you in advance.
- JamesGLNETGEAR Employee Retired
Hi gaziou,
I just want to verify if you have followed the instructions given on the KB article below.
JamesGL
Community Team
