qwerty77's avatar
qwerty77
R7000 OpenVPN latency,ping,slow
Hi all,   When I'm connecting via VPN to my home network, everything is very slowly and laggy.  My router has IP address 192.168.2.1 and I see this rule below in the client log and it seems like t...
  • qwerty77's avatar
    Nov 17, 2017
    Topic can be closed. Setting the TUN and TAP Servicetype to TCP instead of UDP gives much better performance.
    Ping results are now around the 11-12 ms.
