Oliver2000
May 16, 2020Aspirant
R7000 orange light
Hi I just bought a r7000 router and I set it up. The problem I am having is that when I turn it on all of the light go white except the light to the right of the power which goes orange I have tried a...
- May 16, 2020Which is a modem/router combo device. Putting you in a double nat situation. It'd also explain the light.
https://kb.netgear.com/30186/What-is-Double-NAT
2 easiest options?
1. place the netcomm in modem only/passthrough mode. contact your isp with help doing that to their device.
2. place the netgear in access point mode. it does disable some function but you'd still be able to use the wireless and ethernet ports. It'd just leave the netcomm in control of the routing functions.
Oliver2000
I'm connected to the NetComm nf10wv (the default one that came with the internet)
May 16, 2020Guru - Experienced User
2 easiest options?
2 easiest options?
