Isaac2156
Nov 23, 2021Aspirant
R7000 Packet Loss
It all started when I hopped on Fortnite with a couple of buddies. I was in a game with them and all of a sudden, it shows that I have severe packet loss and I lag so much on there. Now, the packet lo...
Nov 23, 2021Guru - Experienced User
Is it happening on wired and wireless?
What modem/gateway do you have?
Have you checked the modem's connect? direct connect the modem to the xbox and see if you still have the same issue
- Isaac2156Nov 23, 2021AspirantI am wireless, no clue about wired. I do have a NETGEAR Cable Modem CM500. What do you mean by checking the Modem’s connect? Connect the modem to the Xbox?
- plemansNov 23, 2021Guru - Experienced User
yes, try it with the xbox directly connected to the modem. That helps determine if its a router issue or a modem/isp issue.
- Isaac2156Nov 23, 2021AspirantUnfortunately , I do not think I will be able to try and do that as both my router and modem are located in the living room, which makes it difficult. I have the power plugged in, the Ethernet cable plugged into the router, and the Cable/Ethernet also plugged in. Is there any other way?
