Retired_Member
Jul 04, 2016R7000 password recall ... remote management
I am a bit upset , having received an e-mail from Netgear , that the security of my router may be compromised via the remote password management process . Getting answers from Netgear is a bit tediou...
TheEther
Jul 04, 2016Guru
storm1985 wrote:NETGEAR Product Vulnerability Advisory: Potential security issue associated with remote management
Actually, I think it's this one (link).
storm1985
Jul 04, 2016Prodigy
yup you're right TheEther
Retired_Member according to this KB link vulnerability only affects R7000 v1.0.5.62_1.1.87
if you have the latest firmware version v1.0.5.70 then you should be okay. Follow the recommendation on the KB as well.
- Retired_MemberJul 04, 2016
I am learning how this forum works ( new to all this ) ; however I am no computer Geek and I am still learning ... So , checking my firmware version , it starts with 1.0.6.28 ... My NetGearGenie states my router is up-to-date . Therefore I am thinking my version is particular to a Mac download . Perhaps this is consistent to the possiblity that there is in fact a distinction between Mac's Safari and PC vulnerabilities ... It would be nice to get a NetGear response to my post .
- TheEtherJul 04, 2016Guru
The vulnerability is on the router itself, not on the Mac or PC. There is no Mac-specific firmware. Routers are agnostic to the computers on your network.
BTW, Netgear recalled 1.0.6.28 due to other bugs. :smileysurprised:
The current, official release is 1.0.5.70. You can download it from here (link).
