Mgwinn
Jul 27, 2016Aspirant
R7000 Port Blocking
Hello. I have set up port forwarding but I would like to restrict the access to it by external inbound IP address.. Is this possible?
- Jul 27, 2016
AFAIK, this is not possible with stock firmware. Some 3rd party firmware can do it. If you are port forwarding to a computer, then you can set up filtering on the computer.
TheEther
Jul 27, 2016Guru
- MgwinnJul 27, 2016Aspirant
thank you. I will be returning this product. A 40$ linksys box can do this just fine. No reason a 160$ netgear can't
