jenkinjohnson
May 19, 2022Aspirant
R7000 Port forwarding does not work
Hello. I am trying to port forward for a server of mine but it seems that our ports are completely closed. I've tried connecting to a VPN, changing off a bunch of settings in my router configuration,...
- May 20, 2022Thanks for the help, but I ended up calling my ISP and they put me onto a different IP that was static.
May 20, 2022Guru - Experienced User
1. what modem/gateway are you connected to?
2. your firmware is out of date. You might try updating (might not help if the issue is related to something else)
jenkinjohnson
May 20, 2022Aspirant
