hyabusa's avatar
hyabusa
r7000 port forwarding failed
Hello,
I recently attempted to setup port forwarding on my new r7000 router and am having some trouble. I tried perusing the forums for other threads with the same issue and tried a few fixes to no avail.
Setup:
-R7000 NightHawk Router - FW  V1.0.9.88_10.2.88
-I believe I veriefied I do not have CGNAT through my ISP as whatismyip.com and my WAN IP (advanced > internet port > IP address) are the same 73.243.xxx.x
- I have set my PC to have a static IP of 192.168.1.3
- I have added udp/tcp forwarding rules for the port range I need (2456-2458) pointing to the destination 192.168.1.3
- I have added windows firewall rules for inbound and oubound for the same port range.  --- While troubleshooting since this did not work, I also have tried disabling my windows firewall entirely to test and that also did not work
- I verified I have the application running so it should be listening on these ports and show open I believe
Any help would be greatly appreciated.
Thanks!
  • > [...] am having some trouble. [...]
       Actual actions?  Actual error message(s)?
       Not everyone's favorite, but I don't recall reading of it causing
    port-forwarding problems.
    > [...] my WAN IP (advanced > internet port > IP address) are the same
    > 73.243.xxx.x
       Sounds good.
       Address Reservation or an actual static address?
       Terminology: A "static" address is configured on the device itself.
    What you configure on a (DHCP server on a) router is a reserved dynamic
    address, not a static address.  Either one should fix the address of a
    device, but some implications are different.
       Same ports internal and external?  Copy+paste of the actual rules
    would be reassuring.
    > [...] also have tried disabling my windows firewall entirely to test
       Ok.
       What is this "the application"?  "should be" and "is" are spelled
    differently for a reason.
       For the usual problems with port forwarding, see:
          https://community.netgear.com/t5/x/x/m-p/1859106
       You seem to have items "1", "2", and "4" covered, but see item "3".
    • hyabusa's avatar
      hyabusa
      Thanks for the reply!
      Actions I believe I described below after you asked but let me know if you need more info... No error message other than a port checker shows "closed" and I can see the game hosted and can join internally from my network but my friend cannot externally.
      I set a static IP on my pc, no reservation is set in the router.
      Yes same ports for external/internal. See attached screenshot.  After posting this thread, I tried setting these up as separate rules for each port instead of the range, but that did not help (a separate service rule for each port, 3 in total 2456 2457 and 2458. Let me know if you want to see that screenshot, can only attach 1 it seems.)
      Application is a game called Valheim - from what I found on various thread it uses the 3 above ports.  (links to threads I checked: https://www.pcgamer.com/valheim-multiplayer-dedicated-server/ and https://www.shacknews.com/article/122720/how-to-set-up-a-valheim-dedicated-server).
      • antinode's avatar
        antinode
        Guru
        > [...] I can see the game hosted and can join internally from my
           Using which IP address?  See item "3".  Test both.
           The danger with that is that the DHCP server in the router could
        still grant that address to some DHCP client device.  (Especially for a
        low value like ".3".)  If you're using real static addresses, then
        shrink the DHCP pool, and use only ex-pool addresses as static
        addresses.  (For example, change ".2" - ".254" to, say, ".5" - ".254".)
        > [...] See attached screenshot. [...]
           Looks ok to me.
