Dracony
Dec 12, 2017Aspirant
R7000 Port Forwarding Not Working
Hi! I'm having some issues with setting up port forwarding on my Nighthawk R7000 router and would like some help. I have the ports set up correctly, as explained in several guides, but all websites a...
- Dec 12, 2017That shouldn't be necessary unless you happened to have changed your router's MAC address. Apart from that, your ISP should put something in their system that ensures that you get a public IP.
Dracony
Will do. On that note, if I ever have to restore the router to factory settings for any reason, will I have to request a public IP again?
