Tedrion
Aug 02, 2018Tutor
R7000 Port Forwarding Not Working
I'm trying to get a program called Fantasy Grounds working, and it requires port forwarding of port 1802. I've done this on the same ISP at other locations, and recently moved to a new place in the s...
- Aug 04, 2018
I found the solution on another forum. This is definitely a bug in the firmware.
There is a low threshold on the static IP address it will allow forwarding to. I was at .78 which was too high. I put my static IP to .10, and then pointed the rule to my new static IP and it worked.
To test this I put my static up to .101 and adjusted the rule. It failed again. I put it back to .10, and it worked again.
microchip8
Aug 02, 2018Master
is the program running when you use that website to check the port status? if the program is not running, that website will report the port as closed
Tedrion
Aug 02, 2018Tutor
No dice. Still not working.
