DSelover
Aug 22, 2019Tutor
R7000 Port Forwarding
Has anyone had an issue where port forwarding stops working after a couple of days after updating to 1.0.9.88? After a reboot it starts working again but only for a while. Thanks Doug
- Aug 25, 2019
Thanks for the advice rolled back to 42 reset and reconfigured all seems to be running smoothly now. (Auto updates off)
thanks doug
microchip8
Aug 22, 2019Master
Last known good firmware for the R7000 is .42. Everything after, including .88, is a total mess with many complaints. I suggest you downgrade to .42 or move to a third party firmware like FreshTomato
DSelover
Aug 23, 2019Tutor
Ok, rolled back my firmware and still having issues. After an hour or so port forwarding stops working if I reboot the router it starts working again for an hour or so. Any Ideas?
Thanks Doug
- myerswAug 23, 2019Master
Did you do a router reset? The hidden button on back, held in for say 10 seconds? Different from reboot.
Then reconfigure as this puts the router configuration back to out of box. Do not use a backup file.
This has fixed issues for folks that have changed firmware versions, both up and down.
