DSelover
Aug 22, 2019Tutor
R7000 Port Forwarding
Has anyone had an issue where port forwarding stops working after a couple of days after updating to 1.0.9.88? After a reboot it starts working again but only for a while. Thanks Doug
- Aug 25, 2019
Thanks for the advice rolled back to 42 reset and reconfigured all seems to be running smoothly now. (Auto updates off)
thanks doug
shadowsports
Aug 23, 2019Hero
***edit, posted this late... sorry.
Doug,
Go back to 1.0.9.42. No reason to beat your head against a wall.
If you spend any amount of time here, you'll see that no one recommends 1.0.9.88 and everyone will recommend 1.0.9.42 for the R7000.
- DSeloverAug 25, 2019Tutor
thanks doug
