tomh4's avatar
tomh4
r7000 ports blocking external hard drive
My Goflex Home external hard drive has dropped off my home network. I do not know why that happened, but for whatever reason, the problem is that the ports it uses to connect to the network, 80 and 4...
  • tomh4's avatar
    tomh4
    Feb 21, 2016
     OK, I figured it out. The ethernet cable going to the router was broken.New ethernet cable, hard drive back online. It was helpful to realize that the hard drive absolutely had to be listed in the "attached devices" page, as you noted, since that prompted me to look again at the physical setup.
    Thanks for your help.
