frankcooz's avatar
frankcooz
R7000 PPTP VPN not working
i have a windows VPN server (PPTP) behimd my Nighthawk R7000 router but the router is not allowing VPN passthrough?? Any ideas? I have ports 1723 TCP/UDP and GRE 47 TCP/UDP forwarded to my VPN serve...
  • frankcooz's avatar
    frankcooz
    Feb 04, 2016
    yes i forwarded manually and yes i selected vpn-pptp from the drop down. I was able to fix the problem though!!! I just removed the vpn-pptp service from the drop down and re-added pptp service again and now all is working fine.
