hantrax
Sep 09, 2020Tutor
R7000 problem
Hi guys, I have an R7000 modem router, connected via WAN to another modem router (broadband modem) A few weeks ago I had a problem, the internet led was flashing fast from white to orange. I did...
- Sep 09, 2020
> the firware installed is V1.0.10.90_10.2.90
https://community.netgear.com/t5/x/x/m-p/1900901#M155834
I'd try different (older or newer) firmware before condemning the
hardware.> If I buy a new router, can I use the R7000 configuration file to
> configure the new router?That should work if "the new router" is an R7000.
> router (broadband modem)Cascadung multiple routers is probably a bad idea, too. What,
exactly, is your (unspecified) "another modem router"? Or is it
actually a "(broadband modem)"? If it is (or includes) a router:Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Set Up the Router as
a WiFi Access Point".
antinode
Sep 09, 2020Guru
hardware.
- hantraxSep 09, 2020Tutor
Thanks...I updated the firmware to the new version and now work fine..
Stefano
