przemekbobrowsk
Apr 24, 2022Follower
R7000 PROBLEM
Hello. I have an unusual problem. I have a network based on Netgear hardware. The basic router is the R7000 which gives a cable signal to three rooms and additionally to the EXT R7000 as an additiona...
Apr 25, 2022Guru - Experienced User
1. what modem/gateway is the router connected to?
2. what firmware is on each r7000?
3. have you noticed when the r7000's drop, what device they're connected to (primary router or AP)?
4. Do you have the r7000's set with separate ssids?
5. Are the r7000's using different wifi channels so they don't interfere with each other?
