Nitenik
Jan 04, 2016Tutor
R7000, Problems with Wireless devices connecting after latest firmware upgrade 1.0.6
I recently upgraded to the latest firmware offered for the R7000... The upgrade went well and my wired PC's all connected with no issues, but many of my wireless devices were not able to connect to ...
- Jan 17, 2016
Hello,
I should let you know, I upgraded to v1.0.6 last night and everything worked. The difference is this time I had to Reset my router to factory settings using the hidden reset button at the back and hold it for about 7-10 seconds. This reset the router to factory settings. I then had to re-enter all of my IP address reservations and word block list, but all of my wireless devices were able to connect. The last time I had done the upgrade, I only rebooted the router, and i had read I had to do a Factory Reset to get it to work properly.
It would have been nice for Netgear to come up with a way to extract the Information form my previous version back-up... it would've saved me a lot of time...
Good Luck
Nitenik
Jan 17, 2016Tutor
Hi Searay, I'm a customer, I don't work for netgear. But you might try the factory reset as this seems to be solving most issues...I agree with you netgear has done poorly with debugging in this firmware version.
