InTheZoneAC
Jan 07, 2017Aspirant
R7000 PS4 Speed/DMZ issues
So let me start by saying the router is pretty much in a default state, nothing extra enabled to cause any overhead or extra processing. Just today I decided to use Address Reservation for all device...
- Jan 08, 2017
thanks for all the help, the root of the issue was the router. I tried enabling dmz again on the ip within the ip reservation, tested the ps4 and nat reports type 2 with speeds consitently above 80Mbps. Tried 10 consecutive tests immediately after one another to see if Nat fails or the D/L speeds crawl and it never did.
clithes
Jan 07, 2017Prodigy
What modem are you using? Is your R7000 in the DMZ for that?
InTheZoneAC
clithes wrote:What modem are you using? Is your R7000 in the DMZ for that?
I'm not using a modem, it's Century Link Fiber and the router connects directly to the wall through a cat6 cable. As stated the DMZ setting was tried within the router's DHCP range and outside of it, both resulted in NAT failed with consistent download speeds.
- TheEtherJan 07, 2017Guru
Let's rephrase the question. Does your R7000 have a public IP address on its Internet/WAN port? If it's private IP address, then there's a router upstream that's blocking ports. You will need to address that first.
- InTheZoneACJan 08, 2017Aspirant
