InTheZoneAC's avatar
InTheZoneAC
R7000 PS4 Speed/DMZ issues
So let me start by saying the router is pretty much in a default state, nothing extra enabled to cause any overhead or extra processing. Just today I decided to use Address Reservation for all device...
  • InTheZoneAC's avatar
    InTheZoneAC
    Jan 08, 2017
    thanks for all the help, the root of the issue was the router. I tried enabling dmz again on the ip within the ip reservation, tested the ps4 and nat reports type 2 with speeds consitently above 80Mbps. Tried 10 consecutive tests immediately after one another to see if Nat fails or the D/L speeds crawl and it never did.
