samapatti
May 06, 2019Aspirant
R7000 QoS Device Prioritization not working with most recent Firmware (V1.0.9.64_10.2.64)
I have had this problem for a while and since a couple of firmware versions ago: When I try to change the device priority in the List of "Attached Devices" when "Dynamic QoS" is active, it doesn't...
- May 13, 2019
With your speeds, you do not need QoS. Seems you have alrady stumbled on this yourself. Please do not worry about reverting to an earlier version of FW. 1.0.9.42 is currently the most stable FW for the R7000. You will not subject your self to additional security vulnerabilites using older FW in this case.
DarrenM
May 08, 2019Sr. NETGEAR Moderator
Have you tried to roll back to an older firmware?
DarrenM
- samapattiMay 09, 2019Aspirant
DarrenM 's Question: Nope, not yet since I also don't remember which one was still working, unfortunately and the security issues, that were present in those, I don't want to risk "rolling back" into really.
To answer the second question by shadowsports :
I've got a 200 MBit/s Download and 12 MBit/s Upload by Cable Vodafone here in Germany since they offer the best value for the already - in comparison to other EU countries quite old network infrastructure in general - relative expensive plans here in this country and the throughputs are decent.
I've just turned the QoS off completely yesterday and the reaction time for websites and in Games seems to have significantly improved, even with these - in comparison to possible maximum Gigabit-Speeds - "slow" speeds I get with my plan.
I might just keep it that way and was even giving the possibility of DD-WRT Firmware an eye now since they seem to have developed some decent firmware for the device, too.
Thanks for the suggestions and feedback though and hope mine helps with hopefully making better firmware for the next version launch somehow still.- shadowsportsMay 13, 2019Hero
