samapatti
May 06, 2019Aspirant
R7000 QoS Device Prioritization not working with most recent Firmware (V1.0.9.64_10.2.64)
I have had this problem for a while and since a couple of firmware versions ago: When I try to change the device priority in the List of "Attached Devices" when "Dynamic QoS" is active, it doesn't...
- May 13, 2019
With your speeds, you do not need QoS. Seems you have alrady stumbled on this yourself. Please do not worry about reverting to an earlier version of FW. 1.0.9.42 is currently the most stable FW for the R7000. You will not subject your self to additional security vulnerabilites using older FW in this case.
shadowsports
May 08, 2019Hero
Just out of curiosity, what bandwidth do you subscribe to, and what speeds (up / down) are you seeing.
