cecyoung
Nov 13, 2024Aspirant
R7000 QOS Performance Optimization database not updating
I have not been able to update the Performance Optimization Database despite it being set on automatic. In the attached picture, the database is over four years old. I have hit the Update Now button...
- Nov 14, 2024
That screenshot shows that you have ~200 Mbps Internet. That is not far off the zone that plemans mentions when QOS is more a hindrance than a help.
Are you an avid gamer? Do you see any slowdowns when on line?
If this is a serious issue, the Netgear's gaming routers with DumaOS may be worth trying.
Otherwise, just get on with your life. But be aware that your R7000 dates back to 2017. If speed is really important, something newer might be worth investigating.
Just another user with time on their hands.
cecyoung
Nov 14, 2024Aspirant
Thanks for the information. QOS was never turned on until this week. I was trying to solve buffering with my streaming devices, a Fire TV stick. Intermittent buffering for 5-20seconds at various times throughout the days. we have a 1GBps service and regularly measure 750MBps on wired computer connection with 1GB NIC and 200MBps on Fire TV which is WiFi connected.
I have disabled the QOS.
JWS9518
Nov 15, 2024Luminary
I will back up what others are saying here. The R7000 is a bit long in the tooth. I used it for years until a couple years ago when it started causing problems because it couldn't handle the internet speed or provide the bandwidth for the number of devices I had at that time anymore. Even though I really liked the router, there came a time when an upgrade was needed. Those demands are even greater now with the new stuff out now.
I really think that is your case here. There are some really good replacements that will handle Wi-fi 6 and even 7 now that you would immediately notice a difference from a 10-year-old router.
