waresoft's avatar
Jul 26, 2017
R7000 QOS Slows Down 200mbps Connection
I have Comcast HighSpeed internet.   I upgraded to their 200mbps speed.   I did have 100mbps.   I had dynamic qos setup for the 100mbps connection and never had a problem.   But with the qos enabled ...
  • TheEther's avatar
    TheEther
    Jul 27, 2017
    QoS is pretty CPU intensive and it only comes into play when your Internet connection is congested.  Unless you are making full use of your Internet connection, you should turn off QoS.
