LexiKC
Mar 23, 2018Aspirant
R7000 randomly dropping Ethernet connection and changing LAN IP address
Hi all Router model: R7000 Firmware version: 1.0.9.26 Issue: Since 01/March I've noticed unusual behaviour involving my R7000 and the Ethernet adaptor on my main PC, a bog standard 2014 HP P...
- Apr 09, 2018
Hi LexiKC,
I would like to follow up on this if you are still having issues with the router.
Please check as well the latest firmware.
https://kb.netgear.com/000055563/R7000-Firmware-Version-1-0-9-28
LexiKC
FYI, I always have the following features turned off:
- Access Control
- Traffic Meter
- QoS
- Parental Controls (Circle)
There's discussion on this board that these may affected LAN performance on 1.0.9.26 firmware, so I wanted to eliminate this as a possible cause of my problem.
