LexiKC
Mar 23, 2018Aspirant
R7000 randomly dropping Ethernet connection and changing LAN IP address
Hi all Router model: R7000 Firmware version: 1.0.9.26 Issue: Since 01/March I've noticed unusual behaviour involving my R7000 and the Ethernet adaptor on my main PC, a bog standard 2014 HP P...
- Apr 09, 2018
Hi LexiKC,
I would like to follow up on this if you are still having issues with the router.
Please check as well the latest firmware.
https://kb.netgear.com/000055563/R7000-Firmware-Version-1-0-9-28
JamesGL
Mar 28, 2018NETGEAR Employee Retired
Hi LexiKC,
To isolate the issue, do you have other computer that we can connect to the router wired and check if it has the same behavior?
Have you tried resetting the router to factory default after the firmware update?
JamesGL
Apr 09, 2018NETGEAR Employee Retired
Hi LexiKC,
- JamesGLApr 18, 2018NETGEAR Employee Retired
Hi LexiKC,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
