Paperboy61
Sep 22, 2022Tutor
R7000 range issue
I have several questions around this issue, but firstly, let me say I have Virgin Media broadband which I found had very poor range, so I invested in a R7000. Unfortunately, despite the Nighthawk app...
Paperboy61
Sep 22, 2022Tutor
Hi, I have to admit that I don't understand much of this! I bought the R7000 because I was informed by Netgear that this would boost my wifi. I put the Virgin hub into modem mode, as instructed and went from there. Is this not right?
As I said in reply to another user, the Netgear app says I am getting 237 download and 25.17 upload, while Ookla says I'm getting only about 35 for each.
What would you suggest I do to make my wifi faster and have more range?
michaelkenward
Sep 22, 2022Guru - Experienced User
That sounds right. At least Virgin's hubs have that option. BT's junk doesn't.
Don't rely in a single test. Where are you running the Ookla test?
The most reliable test is with a browser and a wired connection. And there are several sites out there. Try more than one.
www.speedtest.net is one of many. But that too depends on what you use to run the test.
Apart from speed tests, do things seem to be as expected?
- Paperboy61Sep 22, 2022Tutor
Connectivity is a bit patchy, but the main problem is that wi-fi can be non-existent upstairs, despite living in a very small house - hence the original question about signal extenders
- FURRYe38Sep 23, 2022Guru - Experienced User
Whats the size of the home? Sq Feet?
- Paperboy61Sep 23, 2022Tutor
Do you know what - I have NO idea! It's a small 2-bed detached house, so tiny, really
