On1y's avatar
On1y
Follower
Apr 27, 2017
R7000 Readyshare printer not detected
Hello, after a firmware update to the lateast firmware, my R7000 is not detected in netgear usb control center. Any solutions? The classic restart doesn't fix the problem.   Thanks!
  • JamesGL's avatar
    Apr 28, 2017
    Hi On1y,
    1. Try to run the control center as administration.
    2. Check as well if the USB ports of the router is working by plugging USB drive.
