Axaao
Aug 18, 2016Aspirant
R7000 rebooting daily
I am having to reboot the router every 24 hours for past few days. I was on 1.0.5.70 when the problem started. I have updated to the latest firmare V1.0.7.2_1.1.93 but that hasn't solved the problem...
- Aug 28, 2016
Hi Axaao,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
JamesGL
Aug 28, 2016NETGEAR Employee Retired
Hi Axaao,
JamesGL
Community Team
Axaao
Aug 28, 2016Aspirant
I simply switch to Asus Merlin firmware before your response and it's been perfectly stable since then. No problems. I never tried factory reset. As of now, I don't have a need to go back to stock firmware or do anything else, as not only the router is stable, but wifi performance (5G) is just as good if not better as stock firmware..
